Album Art (cover.png) not showing
Hello
I have some albums with ‘cover.png’ files inside the album folders (and no covers embedded) but they are not showing inside the app unless I assign them to the songs manually. ‘cover.jpg’ files and embedded covers are showing just fine.
Upload description: To create the log file I played a song of an album that has a cover.png inside its directory and then assigned the cover to it. I also uploaded the cover file.
I need logs during a sync with a clear tag done before.
Thanks for replying so quickly
I have done the sync and hope you meant the >clear media cache option.
Identifier is my username
No I meant clear tag cache in the provider settings.
And I’ll need the name of the albums that does not have the cover found to match things.
Ok :ok_hand: Just uploaded the new log.
Album names are:
2
Eversince
13
Das Beste Von Kurz Nach Früher Bis Jetze
Das ist nicht die ganze Wahrheit …
Devil
Die Ärzte
Die Bestie in Menschengestalt
Geräusch
Im Schatten der Ärzte
Ist Das Alles? (13 Höhepunkte Mit Den Ärzten)
Jazz ist anders
Le Frisur
Planet Punk
Runter mit den Spendierhosen, Unsichtbarer!
Acid Disk 2
Paths
winter
MEGATON KICK 3
fall like a leaf
COMPLE:X 3.0
if yur mine…tell me now…
lying2you #ae #x9p
astral beach
session
everything i do is for you
My Spring Break Doodles
CRISIS VISION
天気の子 complete version
すずめの戸締まり
L’été
Love Magic
love songs
Ordinary Songs 2
Snö
エイリアン☆ポップ II
Existing & Lingering
#me
STRIKE A KICK 4
Silversun
とらドラ! オリジナル・サウンドトラック
ぶっ生き返す
Thanks, I wrote too fast but I needed just one or 2 to match things.
Seems my png fix is not applied to local device, will be fixed in next release.
Thanks a lot for the great work!
Symfonium is such a beautiful player <3
I’m happy that this issue will be fixed now :innocent:
