Add an advanced Title Mix to make a Mix based on Tracks Features like Artist, Genre, BPM, …
For example a Mix with Linkin Park and Rock.
I"m sure that with a little effort you could have done it with even less word so that I needed to guess more how this should work …
I honestly have no idea what to do from your request, the template is here for a reason …
Pretty sure you can achieve what you want with smart filters and run the personal mix on them.
Sorry about the length.
But you solved this.
Never thought about doing this with smart filters.
Thanks
