Hello! I was editing the Now Playing screen’s control button bar, and wanted to set the style of the shuffle and repeat icons to start off as default, but then change to the primary colour when they are pressed on / active, like Spotify does.
Having the icons take on the primary colour only when they are active / pressed on is a good indicator for the user that the action is active. At the moment, there’s only the option of having it take on the primary colour all the time, the default colour all the time, or the overlays.
Provide a good indicator for the user that the action is active
This is how it’s done with Spotify. I’ve attached some screenshots below.
Notice how the repeat icon at the bottom-right turns green when it’s active:
