Symfonium is a great app that I use every day, the only thing missing for me is the ability to play songs with voice commands like in Yatse.
Only a few commands like these ones would be great:
- Play album …
- Play song …
- Play artist …
- Play playlist …
I imagine that it’s not an easy task, and I will fully understand that it will be low priority on your list…
If you have a big musical collection, it can be sometimes tough to select songs to play (even if the search feature works great, and do the job most of the time).
It will also allow to change the music when you are doing something else with your hands (or your hands are dirty): like cooking, tinkering, gardening…
Faster and easier for the user to select music.
The way voice commands works in Yatse is perfect. I’m using the Yatse voice command widget on a daily basis and it’s really useful.
Again, something like Yatse: microphone icon on the home screen and a 1x1 widget would be perfect.
