Add the option for "Toggle lyrics and cover" button in cover shortcut and actions
I would like to access the toggle cover and lyrics button from all the tap actions available for the cover (tap action, double tap action, long press action) as well as from the shortcuts available for the cover in all four corners. And anywhere else it might be missing within the extended player customization options.
I want to be able to toggle between lyrics and the cover by double tapping the cover since that’s more reachable with my hand. And while we’re at it, it would be good to have that option in all the other cover actions and shortcuts in case someone else wants to do it a different way.
More consistency, as currently the option for the “Toggle lyrics and cover” button is only available in certain actions and shortcuts but not on others. Also it would allow for more flexibility for customization at no cost for the user interface.
The following screenshots are within Settings - Interface -Now Playing Screens - Extended Player (portrait) - Cover art settings
It’s not on a couple of place because you can’t come back then :wink:
There’s no bottom left icon when the cover is gone, there’s no double tap on cover when there’s no cover too :wink:
okay but why not in the bottom bar? that can only open the full lyric view and there’s no option to toggle it there either?
Well considering that it’s there and is even the default in the default theme you might want to check again :wink:
Oh i see, that makes sense. Could there potentially be a workaround tho? Like an added button to toggle back if there’s no other on screen (maybe that’s not the most elegant solution but it’s just an idea). Or maybe some gesture? Maybe like a pinch in gesture to go in and a pinch out gesture to go back to cover. Honestly even double tap on the lyrics could work, since currently it’s only a single tap that causes interactions with the lyrics interface, but double taps isn’t used there yet. If it’s not possible, that’s ok tho, i can live without it.
