Add setting to determine an alternate way to identify compilations
Hello
Would it be possible to create an option in settings to change the way to determine if an album is a compilation and ignore the normal way?
For example, if the album artist tag is Various Artists or Various this could be used to identify a compilation.
My set up does not use the compilation tag so only a few show as compilations. This in turn also messes up the Album Artist and All Artist categories.
I hope this is a possible fix as I feel it could benefit a lot of users and hopefully isn’t too difficult to implement.
Great app and thanks for your hard work and continued support.
If you can already identify the files with Various Artists or Various for album artist, what’s stopping you from tagging them as compilations?
Generally, if an issue can be fixed by amending your tags then that’s going to be the way forward
Apologies, I thought I put this in requests.
