Add search by ratings
Star ratings are stored so why not use them as a filter ? Adding a filter such as minimum stars > 1 or stars = 5 would allow to skim through very large libraries and get cured playlists easily
n/a, it’s just an enhancement
see above
I don’t know if other applications provide this. I’ve mostly used Symfonium
Ratings can already be used by the mix algorithm and the sort functionality
n/a
Already there and much more
Ah my apology, i totally missed that. I only used the search button next to seeings below. It’s great to see it’s already there. Feature request closed then : )
