I’d love if it was possible to add discsubtitle to the string options for the now playing screen.
It would add more details for any song from a boxset, to know which album from that set is playing.
More clarification for the songs you play.
2
@Tolriq since it says implemented:
Which specific tag(s) is/are supported now?
Some people use SUBTITLE, others DISCSUBTITLE and for live recordings I’ve also often seen SETSUBTITLE.
Tolriq
3
You use LMS it’s @itm question
itm
4
Lms uses DISCSUBTITLE and SETSUBTITLE
Just noticed support for the SETSUBTITLE atom in Symfonium
I have a small nitpick. It seems like only one SETSUBTITLE is picked up for the same ALBUM + DISCNUMBER.
The below album as shown in MusicBee
seems to be grouped as “Act II: Charlatans and Saints” in Symfonium. I only have tracks from Act I to Act III in Symfonium.
This is also why I use SETSUBTITLE instead of DISCSUBTITLE.
Fwiiw: I use the below virtual tag in MusicBee for sub-headers:
$If(<Disc Count>>1,$IsNull(<Set Subtitle>,"• Disc "<Disc#>" •","• Disc "<Disc#>" • "<Set Subtitle>" •"),$IsNull(<Set Subtitle>,,"• "<Set Subtitle>" •"))
I switched set subtitle to grouping as that one seems to more fit the definition of a subset of tracks.
