Hi! Is it possible to add customization/settings for the “recently added tracks” auto-playlist? Such as limiting the track count or setting a date (ie. only tracks 3 months or newer appear in the playlist).
My current problem is thatI recently got a new phone (not sure if the problem is the same for longer use, i believe it was on my previous phone as well) and the track count cap of 1000 essentially makes it not a recently added playlist. I like to shuffle new tracks, and most of those tracks are new.
I believe this would improve the overall functionality of the playlist, so everyone can customize their own definition of what a “recently added” track means. Or just be able to make it a smaller playlist for a more precise mix.
Other apps I have used allow you to set the “how old” rule for the playlist as sugested above.
