The option to add additional sections to the home screen that display the contents / results of a selected saved smart filter
More customizability and enhanced usability
Say you have a custom filter based upon play count or offline status or user rating or anything else, those could be displayed directly on the home page under a custom header
Idk why this post is giving me Deja Vu but I like this idea.
I will say the dev will probably tell you the current equivalent for this is to create a smart playlist with whatever name suits you. Taking it a step further If you wanted you could even add the playlists shortcut to your home screen & you’re just one tap away from an infinite number of smartly gathered tracks.
