Be sure to search for existing feature requests before making a new one.
While the application is 100% user driven not every feature request will be accepted, they can be out of the application scope, too complex, or too specific.
Keep the template and fill it with as much details as possible
When switching from WiFi to Mobile Data the app should adapt accordingly and switch to transcoding. This is especially useful when you listen to FLAC on Wifi but have a limited data plan.
If you are in the middle of a longer song and realize that you were streaming FLAC direct all along this can add up to a lot of data consumption. Right now you have to play a new song for the transcoding changes to take effect, so you would have to play the current song from the beginning and seek manually to where you left off.
I don’t expect this switch to be silent, and it would even be acceptable for it to take effect when pausing. That way you don’t get a lot of gaps when constantly switching back and forth.
I imagine reevaluating the current connection when the user hits play and adapting the transcoding mode according to that should be enough.
A nice addition would be switching the little cycling info snippet to the audio format to show the user that the switch worked.
For users that listen to high-res files at home/on Wifi but have a limited data plan and would like to reduce the bitrate in the go it would be practical for this switch to just be a simple pause/play again.
Most streaming services do this, I’m not sure how it is done technically.
If possible please provide screenshots of your idea of the implementation or how other application do this.
