Accessing Emby library remotely
I submitted logs through the app.
I am trying to connect to my emby library remotely but Symfonium keeps saying it cannot connect. The remote ip works in my browser.
I am adding the remote ip as a secondary connection to the library.
Upload description: Bigmack3000
Emby library syncd through local connection. Trying to add remote ip as a secondary connection.
Emby
To be able to edit an host the first IP must be working.
You can triple click on Emby header at top to enable to bypass this check.
So I can’t fix it until I’m back on my local network first?
Nvm. I found what to triple click. Working now. Thanks.
You can also just invert the hosts.
There are not really primary and secondary at usage. Just for the configuration part.
