Ability to stream synced lyrics within a widget
Hi there,
Being able to stream synced lyrics within the app is a huge step for my ideal setup, and I’m so glad I found this app.
Well, now I have a secret dream but I am clueless about it being feasible, too specific, easy or not, etc.
well, actually, I know it’s specific and niche… but I prefer to ask!
I would like that synced lyrics are shown (and, well, synchronized) in a widget, the most useful being a widget on the lock screen.
Not really a problem, mostly sugar. I am a native French speaker and while I mostly understand spoken english, it’s quite hard for me to follow lyrics, and it’s important for me sometimes to know if I can relate or not.
I imagine not understanding a part of a song, waking up my phone, tap “-10s” or just slide the timeline, and immediatly seeing lyrics. For me, it’s a wonderful, frictionless usage and I miss it almost everyday.
For the others… probably not?
Existing bricks:
  • I tested LockScreenWidgets, still in alpha phase and asking for a lot of dangerous permissions due to the way lock screen is protected, but a wonderful piece of software, works quite well !
  • I am aware of an app named KWGT that can create custom widgets: could it help?
While I am familiar with computing stuff, I really know nothing about Android, so if something is a anti-pattern well I’ll let it go.
Google have removed lock screen widgets since ages.
You can enable the keep screen on option when lyrics are shown that my prevent lock screen to activate.
As I mentionned the third-party app is able to restore lock-screen widgets, see pictuee attached!
This is not really lockscreen widgets, this is draw over other app widgets. With as you said all the security impacts of such things.
Ok I think I understand your point better; i.e. given that no “lock-screen widget” can exist without using hackish/potentially dangerous stuff, designing a widget which only makes sense in this context is pointless; is that it?
I’m still being curious about the difficulty of coding the widget itself, and if it could be added one day.
For example I found a KGWT widget with scrolling, dynamic offline lyrics (see below), but KGWT is bloated with ads, demanding dangerous perms and closed-source : it is Symfonium which plays the song visible on the screenshot.
