Ability to Perform Math on Smart Playlist/Filter Rules
In addition to the existing Smart Playlist/Filter rules that allow you to access data related to metadata and play data, it would be useful to be able to perform math using the numerical data.
Say you want to create a smart playlist with your most played tracks, but want a more filtered result. With this feature, you could set rules that look like the following:
(Play count - Skip count) greater than (0)
This is technically already possible with Any/All option. You could require a playlist only include songs above a specific number of plays and under a specific number of skips. However, this feature would allow for greater customization as this kind of thing could be achieved in many different ways with different results with a math filter feature. For example, the previous scenario could be done differently:
((Skip count * 0.5) / Play count) less than (1). Allowing you to weight one option or the other to your preference.
Sorry but way too niche and complicated both from UX and code POV.
Couldn’t this just be implemented on top of the smart playlist/filter rule system? You could create rule entries for numerals and operators like +,-,*,/ etc. It may require an adjustment for passing the result of whatever math is performed through as a filter rule. I feel like this feature would greatly expand the usage of many.
This needs complicated interface for users to enter those and manage parenthesis and all the math stuff :slight_smile:
Then it needs an even more complicated handling to convert all that to actionable SQL.
For something that maybe 2 users will use.
