I’ve managed to download/cache most of my playlists, without issue, and they all say “status: fully cached.” A couple of them, however, say “partially cahced” no matter what I do. I’ve tried using “remove from cache” and turning off auto-cache, and then re-applying the “add to permanent cache” and auto-caching again, I’ve tried restating the app (and my phone), nothing seems to get them to “fully cached” status.
Plex
I cannot reproduce the problem. 8 out of 10 playlists work fine. It’s these two. That’s why I need help; I can’t determine where the issue lies.
What I’m doing to cache the playlist is:
- Select one of the two problematic playlists
- Tap the 3 dots in the top right.
- Tap offline cache and download
- Select “add to permanent cache.”
- Return to the previous menu
- Click “configure auto offline cache”
- Select “enabled.”
- Click “apply.”
Nothing appears in the download queue, and the playlist still shows as “partially cached.”
WraithTDK
