If related to media, be sure to explain for what media provider this request is.
Add as much details as possible.
Please be precise about your need and not the solution you think you need.
A-B repeat, as in Musicolet and other desktop media players. You pick the start and end region of a looping region and it plays starting from point A until point B, where it seamlessly continues playback at point A
Describe your problem precisely as it’s more important than the solution you may think of.
I need to practice just a region of certain music and currently need to use a different application for this
Explain what benefits it brings to all users and not just you and your possibly very unique need.
Thisbisba common feature in desktop music players and tbh idk what non musicians use it for. It can allow for repeating single songs out of a larger medley or concert audio file though
If other applications have solved this, please describe their solution (If it fits your needs, else explain why their solution is not perfect)
Musicolet has implemented this, along with an audio file region cutting/export tool, and it’s wonderful and fits my needs quite perfectly. The UX is quite simple but it does the job well.
The more details the better to understand the need and figure out the best solution.
If possible please provide screenshots of your idea of the implementation or how other application do this.
