3 issues in 1 report (hoping doing right)
I have found 3 issues in latest beta release
  1. Country tag not showing
  2. Haptic rating stars not working
  3. Theme settings working weird
Upload description: Zyntaxyz
I have more screenshots if helps (theme settings)
I reproduced the 3 issues while debug mode was active (tweaking theme settings, rating songs and activating/deactivating country in about album page settings)
The first ss shows the country tag is already tagged
The second one shows the theme issue and country issue
The third one shows my custome theme in 11.4 stable release
The last one shows the same custom theme in the latest beta
Please don’t mix completely unrelated issues in the same issue it’s impossible to follow.
For the country part, that tag does not exist see for example Tag Field Mappings – Mp3tag Documentation for valid tags for that.
With that said I can probably add support for that custom one.
Haptic definitively works unless disabled at os level.
Edit: For the theme part, Google fixed the chips outline to be consistent per the spec. So the border is now outlineVariant and no more outline. (This is consistent with your buttons at the top that does not have a border in your theme.)
Are we currently just using MUSICBRAINZ_ALBUMRELEASECOUNTRY then?
RELEASECOUNTRY is supported too
I have no problem to move the custom country tag to the supported ones :slightly_smiling_face:
I tried enabling/disabling haptic function in my Redmi note 10 MIUI 12.5 but still doesn’t work
So, about theme issue, my custom theme will not look as 11.4 anymore right?
Yes the chips now use another color for the border, but you can tweak the theme to to adap.
I’ve added support for raw COUNTRY in future version.
