24/96 FLAC File Sound's Low In Volume Compared To 24/48 FLAC File
I have a FLAC file which is 24 bit (24/96) and another FLAC file which is also 24 bit but (24/48). When I play the 96kHz one it sounds very low in volume even when the volume is unchanged on the device compared to the 48kHz file.
The 24/96 kHz file plays properly on a PC without decrease in volume.
Upload description: Uploaded logs along with both the FLAC files, description: AA-2496-debug.log
I have uploaded 2 files. The one named “Nurko” is the 24/96 kHz file and the one named “Manshn” is the 24/48 kHz file.
Android Version: 12
Symfonium Version: 11.1.0B1
1.) Play the 24/48 kHz FLAC file at normal listening volume.
2.) Play the 24/96 kHz FLAC file without changing the volume. (It sounds low compared to the first one)
Google Drive
They both sound the same on speaker and BT.
Sorry, I meant on earphones. I use these earphones to listen to audio if it helps.
Well this is something your device do. Try on speaker and on BT and if it sound the same then you know.
I have no BT but I tried on speaker and it is playing normally without any issue.
Then you know it’s not Symfonium :slight_smile:
Thanks for the help.
