14.0.0B1 NPS Preview - Bool - Long Press doesn't toggle
The long-press String action to “Toggle bool” has no effect in the NPS Preview. (Works correctly on actual NPS. Tap action also works in both)
Upload description: Celorien_NPS_PreviewBool
Captures long-press in live NPS first, then in preview NPS
Additional log: Celorien_TapVsLong
Captures both tap action and long-press action, inside preview screen.
Was specifically tested with String 3 to set Bool5, will verify others but I assume they’ll all do the same.
Confirmed, affects all. Built a demo NPS for easy testing:
nps-bool toggle test-20260212_172902-symfonium.json (32.2 KB)
Each number toggles visibility of the one above it.
String 3 action’s long-press set to “toggle bool5”
String 4’s custom text set to:
{Test%|bool5==“false”%}
“Test” is printed by default. In preview, long-press String 3. “Test” remains visible.
Try again in actual NPS. Visibility of “Test” will be correctly toggled.
