Playback stops after each track when casting to upnp speakers
When playing to my WiFi speakers using upnp, playback stops at the end of each track when playing an album. Even playback is on the local device playback continues to the next track
Upload description: Andywarb
Your logs are empty and do not reproduce the issue.
Your device probably have a broken gapless support, you can disable it in Symfonium renderer setting for that device.
The logs were produced when the issue happened. I tried disabling gapless support.
The track stops at the end and doesn’t move on to the next track in the album and the play button changes to indicate it has stopped.
I have Navidrome running on a raspberry pi and Symfonium connects to it using the subsonic interface. I’m casting playback using upnp to Argon Forte A5 WiFi speakers.
Is there any other information I can give you?
Well as said the logs are empty, telling me they are not won’t change them.
So provide proper logs. Stop casting enable logs then connect to speaker and fully reproduce.
did you enable debug mode?
Yes I did. I’ll try again and check the log file.
Apologies if I did something wrong with the previous debug log file. I’ve just uploaded another, created while reproducing the issue.
I think the issue is resolved. I found another Speaker device appeared when casting with the same name but with DLNA appended to it. When I selected this device the playback continues to the next track. So please don’t spend time analysing the logs I sent.
Thanks
