Loudness Normalisation for Plex
Unlike local files or some other providers, music acquired from Plex does not have any replay gain or loudness normalisation, even if the native files had replay gain data in it. Plex instead calculates and saves this info elsewhere, and can be viewed in the item’s XML file.
Loudness normalisation for people who host their music on Plex.
All Plex users can enjoy loudness normalisation like all other users who utilise other providers or storage methods.
Plex (and Plexamp by extension) store the loudness information separately from the media files. This information can be ascertained in the library metadata ( see screenshot 1).
Grab album/song loudness values from Plex library metadata. XML query of a random song is provided in Screenshot 1. Screenshot 2 is a UI screenshot of Plex shows the same song’s loudness information.
Unfortunately AFAIK there’s no real track / album difference for Plex. Never understood how they calculate things. Try to find a song with a different value for album and track.
And the other issue is a waiting feature from ExoPlayer.
Here’s the next album over. Completely different values as far as I can tell.
There’s still only 1 gain value album gain and gain are both -3.93.
Most people have and want different values when playing albums or random tracks.
Ah I see what you mean - they seem to be the same. Wonder how it’s accounted for then, because I can definitely tell you I don’t get the extreme volume swings in Plexamp…
If I was to assume, based on Plexamp’s description of preamp: all songs are normalised to -18 LUFS (so based on the Loudness parameter?) if not based on album loudness. If the limiter is enabled, I presume loudness is decreased if peak exceeds 1.0.
RGI just did a bit of comparison between the Replay Gain tags generated from Musicbee, and the values from Plex.
The RG values from the FLAC metadata and Plex:
And for another song:
And another:
Looks like the RG and Plex loudness songs are closely related and hinges on the -18dB reference. Or:
RG = -(loudness) -18
Album loudness is a bit more puzzling, I must admit…
