There is the option to filter what’s been off-lined, but nothing to filter what isn’t off-lined.
Just an extra filter feature
Good filtering
Tolriq
2
What is the actual need to have a global filter for that?
You can use smart filters in lists for this. I don’t see any use case for a global one.
Hi @Tolriq
Thank you for your prompt reply
A couple of us have looked into this and couldn’t see a filter group that would suit this need under smart filter. Which one would we use?
The request was from a friend who is currently using Symfonium whilst on holiday in the USA.
He can see his whole library, he can see what is currently off-lined but would like to see what isn’t off-lined separately.
Is there an option for a UI tweak to have an icon on the albums thumbnail in the libraries album view?
Many thanks
Tolriq
4
Hum I was persuaded that the smart filter was there but seems not :). Will add.
There’s already a different request for the album indicator.
