When making a backup, an app selection pops up to hand over the backup file. I use TotalCommander at that point to write the file to SD card. This always fails on the first attempt - a file with 0 length is written to the selected target directory, and an error message appears. I have to select the backup again in “Manage backups”, hit the share button and select TotalCommander again. On this second attempt, it works.
Not surenif you can do anything about it or if it is a TotalCommander problem.
Sent via email: 20230516_163940
