[Wiki] Settings - Playback
Notes:
  • Some settings may not be available on all Android version and some may only be visible when other related settings are enabled.
  • The application evolve frequently and in some cases the documentation can be late, just leave a message in the chat if you find an issue with the docs.
Headset button
Single click
Action to trigger on a single click on the headset button
Double click
Action to trigger on a double click on the headset button
Triple click
Action to trigger on a triple click on the headset button
Remap next button
Some devices do not allow click remapping, you can then remap the triggered action.
Remap previous button
Slower click detection
Increase the delay between clicks to detect double and triple clicks.
Playback
Equalizer - DSP
Open the equalizer and DSP configuration page. See [Wiki] Advanced Equalizer / AutoEQ
Playback state saving
Save the current playback state and queue to always be able to resume current queue even after an app kill or phone reboot.
Cellular maximum bitrate
If your server support it, limit the media bitrate when connected to cellular network (Transcoding)
Force instant transcoding
When transcoding for cellular and loosing wifi, instantly restart the playback in transcoding mode to reduce network data usage.
Wifi maximum bitrate
If your server support it, limit the media bitrate when connected to wifi network (Transcoding)
Playback cache size
Configure the size of the playback cache. When enabled Symfonium will try to pre cache the current songs and the following queued songs to better support slow cellular network or network interruption.
The number of queued songs pre cache increase with the size of the cache.
Retain shuffle and repeat mode
Why default when you start a new playback the shuffle and repeat mode are reset. Enable this option to keep their previous value.
Remember last renderer
Enable this option to try to reconnect to the last selected player on application start.
Automatic actions
Continuous playback
Enable this action to have Symfonium automatically queue some new songs when you reach the end of your current queue. Those songs will be based on the last few songs genre and creates an “infinite” radio mode. (
Volume auto play / pause
Automatically pause the playback when you set your phone volume to 0.
Headphone auto play
Automatically resume playback when you plug your headphone.
Bluetooth auto play
Automatically resume playback when you connect your Bluetooth headphone. This requires an Android permission that you need to accept.
Advanced
Multiple media queues
Enable support for multiple media queues. See [Wiki] Multiple media queues
Short audio focus action
Change the default action when another app takes the audio focus for a small time (Like Google maps)
Prefer internal decoder
Prefer the usage of Symfonium internal decoder, this improve codec support and fix a few devices bugs, but can use a little more battery.
Offload mode
When using the device decoder, try to completely offload everything to the phone audio processor to reduce battery usage. On some device when combined with the Hi-Res settings this allows to bypass some phone sample rate limits.
Local renderer Hi-Res
On devices that support it try to render the media at higher quality when the source is higher quality. (Will disable a few audio processorts like playback speed, skip silence, …)
Transcoding engine
Enable the internal transcoding ending to play a lot of new audio format like DSD, MPC, APE, …
Min. play percentage before marking as played
The minimum playback percentage needed before Symfonium mark a media as played.
Min. play time before saving resume point
The minimum playback duration needed before Symfonium save a resume point. Set to to never to disable the resume functionality.
Enable pitch control
Enable pitch control in the playback speed panel. You can disable this option to simplify the playback speed screen if you never use the option.
Restore defaults
This button restores all settings on this page to their default values. You can also use the backup and restore function to switch between different configurations of the settings with ease. ([Wiki] Settings - Backup & restore)
