Wifi-specific secondary connection
Add the possibility to only use the secondary connection when connected to a specific WiFi.
Most firewalls block dynamic DNS, which are commonly used as music servers. This would allow using a dedicated URL to circumvent restrictions
Avoid connectivity problems when using workplace/institutional wifi
Other application solutions
Other applications have a drop-down menu to select which wifi uses which connection
Duplicate of many use tasker or automate and the API for that. This require precise location permission that’s not a permission that suits an audio player app.
