What exactly does the "Force first song pre-cache" do?
Hello. Before I go and make a support request, I want to figure out if this is a bug or not.
So I have my playback settings to force the first song to pre-cache. However I noticed that when I have this setting enabled, each time I manually skip a song or go back to the previous song, the app needs to load in the song if it wasn’t already cached before I started a queue of music. This loading doesn’t happen when the current song ends normally and the next one plays on its own.
To note, this happens both on my local network (where my music server lives) with wifi and remote. But the loading time for when I’m in my home network is almost instantaneous. It’s when I’m outside using my phone’s LTE connection that I have to wait a few seconds before the uncached song plays after manually skipping back or forth.
As a prenote:
  • I have set the song UI to show icons if they’re offline/rolling cached
  • Set the playback cache size to 3GB
  • Set the pre-cache tracks size to 12 tracks for both mobile and wifi
  • I have the “Add playback cached media to offline rolling cache” setting enabled
So I find this issue weird because when I pull up on the playback screen to open the “up next” view, I can see that not all of the next 12 songs are cached from offline settings or the rolling cache. I expect all 12 of the upcoming tracks to be placed in to the rolling cache (as per the setting from earlier) if they’re not already in the offline cache. Yet for the songs from those 12 that don’t have a cached icon, I can tap on their 3-dot menus to open their details and it states that they’re in the rolling cache. Turns out stopping the queue fully by stopping the music, then re-entering the queue fixes this issue and all the 12 songs now have the cache icon to them. These songs also no longer experience the loading issue from forcing the first song pre-cache when I manually skip between them.
When I have the force first song pre-cache disabled, I can skip without this loading time. Does the setting apply to each song? I thought it only forced you to wait for the very first song of a queue as it’s being loaded into your playback cache.
Honestly, I also believe there’s something wrong with the playback cache as I can’t get a song to start playing when it’s supposedly in the playback cache and I cut off my phone’s connection from the music server (with the “force instant transcoding” option disabled). Just not sure if this would be another issue apart from the force first song pre-cache issue.
