WebDAV (Yandex) sync error
I’m trying to sync my library through webDAV (Yandex), but it’s ending with error
(I hope the logs are attached, I’m new to this forum, app didn’t give any messages if logs are successfully uploaded or not, but it’s shows error message if I’m trying to upload log with same name twice, so apparently they should be loaded. Also I’ve didn’t find media provider related to my problem in the menu, neither WebDAV nor Yandex Disk)
All
  1. Open sync menu
  2. Trying to sync webDAV source
  3. Error
I have a paid version of app
aboba
There’s no log uploaded, if it gives an error then it fails, there’s no dupe checks.
Manually upload the logs they are probably too large, or generate smaller logs.
Thank you for reply :folded_hands:
I’ve successfully uploaded log through website, and indicated the same identification word in the description
2026-04-24 15:25:04.729 Verbose WebDav  <-- [194] 429 Too Many Requests https://webdav.yandex.ru/!music/xxxxxx/ (102ms, 42-byte body)
They block the app after some time.
Is there any way to fix this? I’m using this cloud storage with some other apps and sync works fine.
Is it possible to add, for example, a pause function between requests in future updates to somehow avoid blocking?
There’s already, seems yandex is one of the worse and often change their rules (and I can’t test) do you use some open source tools so I can check if they have specific yandex cheats ?
Well, it’s not open source I think, but I’m using “murglar” to mount webdav, and then using “poweramp” player, it’s works not perfectly, but I don’t get any “too many requests” errors out there.
Also I was trying DAVx5 app, it’s open source, but I don’t think it’s works well, but maybe there is some tweaks in code.
Also I was trying “murglar” in combination with symfonium, but sync was very very slow and weird, as if I will be needed to sit with the screen on for half a day so that the synchronization would be successful and not interrupted accidentally.
Most successfully is AIMP, but for windows (android version is very odd for some reason), it’s sync through webdav and updates the lybrary very fast and without any problems, maybe it’s possible to check AIMP plugins code somehow to find something related to yandex webdav?
