Volume not increasing on single tap but only on double tap
Hi, the volume bar in the expanded now playing screen only increases the volume on double tap rather than single tap. When I double tap it, it increases the volume one step which is perfect but curious why it doesn’t happen with single tap. I think the problem might be the device OS I’m not sure.
Upload description: AA-volstepdebug.log
The volume increase animation shows but falls back to the before audio level immediately without any increase in audio while single tapping it. Double tapping it does increase the volume.
1.) Play a song MP3/FLAC
2.) In the expanded now playing menu click the vol increase button
Any provider
VID-20240611-WA0001
So yes it’s your device doing something strange.
2024-06-11 10:10:40.060 Verbose/MusicPlayer: Set volume 36
2024-06-11 10:10:40.061 Verbose/VolumeController: From Renderer: 36
2024-06-11 10:10:40.062 Verbose/VolumeController: From Renderer: 36
2024-06-11 10:10:40.301 Verbose/VolumeController: From Renderer: 31
2024-06-11 10:10:40.302 Verbose/VolumeController: From Renderer: 31
I set the volume then it auto rollback.
Are you connected to some BT device or something?
I’ll add more logs to see if there’s rounding errors somewhere.
I’m not connected to bluetooth, just my regular wired headphones from realme (Realme Buds 2) my device has a 3.5mm jack.
Alright, I see that the next version will have more logs so I’ll reproduce it again with new logs. Thanks for your help tolriq😀
