USB playback output
Beta
Music playing through DAC but it is not showing up as ouput.
Ouput displays as Phone (speaker) even though audio is playing through the DAC
Subsonic (Open)
1 Play Anything
2 Connect DAC
3 Music plays through DAC but it doesn’t show as output
It works fine on my Android 16 Tab
But issue on Android 12 Phone
Issue arose after Beta 3 update
Worked fine before that
So no USB exclusive mode like before
Even reinstalled the app but issue persists
kage125_notdetect
Also the popup that use to appear to get access for USB doesn’t show up on phone when I open the app
@Tolriq could you please look into this
This is the week end and we are Sunday are you sure this message was necessary?
Similar issue. Whilst playing on phone, the phone output is selected, when connecting to Bluetooth/AA the output briefly changes to the correct ‘everest’ output but changes back to phone. Log uploaded. When using my headphones the process works correctly.
@Tolriq
Thank You for the beta 4
This issue is somewhat fixed as it shows the usb in dsp while playing.
But came across something new in the device which had this issue.
Now the entire usb exclusive option is missing in when you check in dsp settings.
Although it shows up in the output tab in the settings but can not be selected as there phone still shows as the current ouput.
Thank You
New Logs :- kage125_usbexclusivemissing
It seems only name heading is changed in DSP rest settings are of Original (Phone) output.
And the pipeline is still treated as Phone output
Can you please give me a reply regarding this @Tolriq
Thank You
What about stop pinging me ? :wink: There’s answers when there’s something to say …
Sorry about that
I pinged just coz you tagged this thread as fixed, so I thought you might missed this.
Thanks
Still persisits after beta 5
Then open another issue with logs as it’s unrelated to the initial issue ?
No it’s the exact same issue that persists since Beta 3 update.
But made a different thread with beta 5 logs anyways.
I guess I can’t read :wink:
And somehow no reaction to that one either :wink:
I’m sorry about that i just saw the name change in dsp and thought the issue got fixed.
The only thing that was fixed was just the change output name in eq section but the actual output pathway used was still the phone rather than usb as seen in screenshots.
So still usb exclusive was not available in the device.
Sorry about that :smiling_face_with_tear::zipper_mouth_face: I thought you missed tha since you were replying to other issues. :saluting_face:
Also thanks a lot for fixing all the volume and DAC and device button issues.
Everything in that context feels smooth after beta 5 update.
