Just updated Symfonium after not updating for many months (waiting for another device to charge enough to turn on that still has an old version of Symfonium to test, but that version should be known-working), and PCM audio no longer streams to UPnP devices (proxy mode disabled) at the file’s native sample rate. No matter what I play (44.1, 96k, etc), I get 48KHz PCM at the renderer.
v13.7 was the version running on my phone previous to updating and is the same version running on this other device, where it does work as expected. I’ll upload a log from the working device as well.
Navidrome
- Select UPnP renderer (worked properly previously)
- Play music with any sample rate other than 48KHz
- Observe input sample rate reported on DAC screen
Ben-upnp & benupnpworks
