Unsupported Media
I know that this is 100% user error, but I simply cannot determine which setting I have wrong. But a few times a day I get a “Unsupported Media” message and the song is skipped. I can’t figure out what I’ve done wrong to have this happen.
Navidrome
It only happens with specific songs it seems, and I can’t determine why.
Log should appear under the name cferneyh. Let me know if you require more info.
I found the failure in your logs. “Sea Legs” by Blondshell is being played from an offline copy that the player cannot recognize as audio. Retrying that same copy leads to the message and skip. This doesn’t point to a wrong playback setting.
Please remove only that track’s offline copy in Symfonium, then try streaming it from Navidrome before downloading it again. Does streaming work, and does a new offline download play?
If a new download also fails, please capture debug logs starting before the download and continuing through playback. Upload them promptly and reply with your app version, upload description, track and occurrence time so I can check how that copy was created.
This has solved my issue - thank you!
