Unable to cast to Google Nest Audio
I am having issue selecting chromecast device as renderer.
It is not playing music and the UI only show infinite loading in play button.
After swapping back to local device renderer, the music resumes normally.
I tried looking at support forum but found no solution. I waited for latest update, problem still persists. I remember not having this issue last time I use Symphonium month (s) ago.
Appreciate if you can look for the issue. Thanks for this wonderful app!
Upload description: coralchoco
  • select chromecast device as renderer
  • play any music
  • UI show infinite loading play button and music is not playing
Your server returns errors when trying to get the media (And why select Jellyfin in the list when it’s Subsonic ;))
It only works locally because the files are offline cached. You can force casting the locally cached media by enabling the prefer offline version on the renderer settings but you need to fix the main issue.
You maybe need to sync again the provider, or fix it’s configuration, I can’t guess more.
Ah I forgot that I have migrated to Navidrome and now using Subsonic. Silly me.
I just noticed that navidrome webpage can’t play any music. After restarting the media server, its working now in Symphonium as well.
I didn’t think to check the provider given how comfortable I am using Symphonium as music client.
Thanks for the support!
