Simply can’t add my jellyfin server onto the android tv version of the app. Jellyfin server is 12.1, can add and works fine with Symphonium on my android phone, when trying to add via Chromecast/Android tv it says that the server is too old and to check the website. Direct credentials and quick connect both yield the same result.
Android TV
Add provider
Input details
Click add
Error message appears
Repeat via quick connect
Same error and option to enable logs
Enable logs repeat above steps (manual entry of info & also direct connect)
Send log
Working fine through jellyfin app and symphonium on Android connects no problem. Multiple other apps connecting to the jellyfin service without issue. I have two chromecasts (different hardware versions) that are exhibiting this behaviour, both were working previously on a windows hosted jellyfin instance (since migrated to a Linux hosted instance, still local)
tbolt2
