Type in loop points
While the A-B Repeat feature is welcomed, I feel like having to press a button to define a loop point is a bit finicky.
The ability to type in the specific loop points would work better in my opinion, you could make it so if you hold the A/B button instead of just pressing it the keyboard appears and asks you to type in the loop points, you could even allow us to type in milliseconds for more precise looping points.
The A-B Repeat feature being a bit hard to use and often leading to loop points that aren’t very smooth.
This would make the A-B Repeat feature way easier to use.
