Treat Wireguard VPN as Mobile connection even when connected to WIFI
Goal:
Have music streamed remotely via VPN + WIFI always transcoded to 320kps while keeping WIFI streamed music as original.
Currently, its only possible to choose one or the other. This is a problem when connected with wireguard and WIFI, which is often times the case when remote.
Allows users to use VPN + Wifi and transcoded high bitrate audio at the same time. While keeping audio original when home, were bitrate is not an issue due to audio equipment, bandwidth.
Allows granular control over transcoding options with use of VPN.
I have uploaded some logs using my username
thekingpin
I tried to replicate, connected to VPN + WIFI, transcode vs original file quality settings.
For now, you can set whatever wifi network you are using with your VPN as a metered connection, and set Symfonium to treat metered connections as mobile networks
Thank you. This exactly solves the issue. :grinning_face:
At least for me this feature request can be closed.
