Translucent Volume and Seek Bars
I’d like the option for translucent Volume and Seek Bars on the now playing screen, and without a handle to manually select it’s position.
With it being transparent, it eliminates the minor issue of some parts of the bars looking less visible depending on the shade of the cover art. It would also mean that the bars would consistently look the same regardless of the color being displayed.
It adds more customization to the app.
Screenshots 1 & 2 are from Apple Music. Screenshots 3 & 4 are from Poweramp.
It should specifically look like the provided examples and manual seeking would be done by dragging the lighter (fuller) looking part of the bar (compare with the bottom progress style when buffering progress is enabled).
