Transition Maestro will randomly stop automatically adding tracks. I have it set to add 4 tracks between songs. It used to work a month or so ago.
Echo match still works as expected. Automatically adding a track after each song in the playlist.
Upload description: rootdown4594
Select and play an imported Plex playlist. Enable Transition Maestro. Songs get added after original first track. After those tracks have played, Transition Maestro will randomly stop adding tracks further down the playlist. If I disable Transition Maestro and then reenable more tracks get added. But then randomly stops again.
Can you make a video of the now playing queue when this happen so I can try to better see what happens when. I can see the issue but hardly the cause due to all the UPnP spam
If you can provide new logs matching the video that would be perfect.
Can you also try to disable gapless on the renderer setting and see if that workaround ? That would help pinpoint the race. (But I’d still need a video / logs when it happens with it enabled)
