Too easy to accidentally change rating when scrolling
When rating stars are displayed on album screen (and probably others), if the user goes to scroll the page and ends up touching the rating stars to do so (even without a pause, just as fluid a motion as possible), the rating will change.
Did not include a log… I know, I’m an awful person, but it’s entirely UI and I dont have my device with symfonium on it with me at the moment. If a log is necessary, just scold me and ill attach one.
Upload description: please forgive my transgression
Perhaps change rating on lift event or some logic to detect whether it’s an intentional tap or a swipe to scroll.
See description
No logs, no video …
Only gesture started over the rating bar can change rating scrolling over can not
That’s the exact situation, with the rating bar set to the middle alignment, at least on my screen size, I keep starting my scroll on the rating bar inadvertently. Scrolling over it does not cause the change, as you say.
If you start a drag over the rating bar then you can drag and drop the value so it works as expected. I can try to tweak but there’s no magic.
Sounds good I’ll probably try a couple different locations for it as well perhaps allowing for different sizes specifically making it smaller might be a solution as well
I appreciate you taking my feedback into consideration :+1:
I don’t need ass licking :wink: I’m used to less then 5% thanks, it was more the no thanks then when an issue instant it’s horrible I want to rollback without any restraint.
Anyway I’ll tweak as much as I can.
:joy::joy::joy::joy::joy:
Just being cordial. Plus we have had, shall we say, moments of friction in the past when I have misunderstood you as telling me that an issue I was having wasn’t happening and I was a dick about it, so…..
But thanks :wink:
