The ‘Blur’ now playing background and the ‘Animated Glow’ as well as the new ‘cover art reflection’ now playing backgrounds are now slow and unoptimized since v.16 beta 1. This also affects the loading time for cover art lyrics and even affects some system software elements.
Update to v.16 Beta 1
Select either the animated glow, cover art reflection or blur now playing theme.
You’ll notice how slow the entire interface gets compared to other backgrounds, including the overly long wait time for cover art lyrics.
It also affected the speed of my it’s control centre.
No screenshots provided, video links provided instead: 68.42 MB folder on MEGA
I’ve uploaded the application style set-up as requested but is also like to point out that I experienced these bugs before I even started customizing my home screen with blur accents.
The blur have not changed it’s actually more efficient and provided by a library.
Your phone was a low cost one 5 years ago, so yes it probably won’t be able to handle tons of high quality blur everywhere + rotation animations and everything you try to put in, you’ll need to be reasonable about what your device can handle.
The adb command does not work. I’ve tried it multiple times and I know it’s a (miui) device issue and not the command itself because this sort of thing has happened multiple times before.
The “official” method of bug reporting (after I searched online) does not give the actual report to users and only sends it directly to Xiaomi. I couldn’t even find a dump file in my file manager.
The bug seems to go whenever I restart my phone so I feel it maybe might be a ram issue?
As I said before, I only affects the full now playing screen. On the homescreen, with blur effects on some media items and the NPS closed or showing only the compact version, it runs as smooth as butter even if a song is playing.
