App version: 14.1.0(127734)
Hello,
I need help with a library synchronization issue. I am using a Hi-Fi Rose RS520 streamer with a 4TB internal SSD. My entire library - 3,558 tracks, consists exclusively of FLAC files.
The Problem:
The sync process is very unstable and extremely slow. It starts by indexing a couple of dozen tracks per minute, but then it completely stops for a while before starting again. Because of these constant interruptions, it took more than 12 hours to index only 1,200 tracks.
What I’ve tried:
- Set the app battery optimization to “Unrestricted” (no effect).
- Disabled “Scrape additional metadata” and “Generate missing thumbnails”.
- Verified that both devices are on the same stable network.
- I started over: completely uninstalled the app and reinstalled it. I checked that the library on the device itself was OK.
- I tried the same thing in another application - BubbleUPnP, everything works quickly and without any problems.
My setup:
Phone: Samsung S26 Plus
Source: Hi-Fi Rose RS520 (Internal SSD via SMB v2/v3), with latest firmware.
Library: 3558 100% FLAC files.
It feels like the connection or the scanner is “stalling” after a short burst of activity. I have attached my debug logs to help you identify the cause.
Thanks in advance!
- Install Symphonium on your device (phone)
- Configure a connection to the streamer with the library via SMB 2/3
- Wait for the sync process. It usually happens quickly, but then stops after reaching the first couple hundred tracks.
Geka4epist
