Sync of Playlists
I have Navidrom installed on a local Ubuntu system (Docker COmpose)
I Have created 5 Playlists, but I can see only 3 of them. All have songs attached, all are public.
I have manually startet the sync , but doesn’t help
Upload description: vbueschken
See only 3 where ? Please make some effort I can only see what you show.
I missen the Playlist in the List of all playlist…
Got it now after ‘import’…. My expectation was that it is synchronized automatically… at least after manual sync.
No you need to import them to decide if you want offline first or online first playlists. The app can’t guess how you’ll use the app so the choice is yours.
