Everything looks fine when I go into my Navidrome library, but Symfonium keeps saying it’s offline when it’s not. What do I do?
Upload description: entity_debug.log
Tolriq
2
2026-01-30 10:38:37.586 Verbose SubsonicLogger <-- [757] HTTP FAILED: java.net.ConnectException: Failed to connect to /10.0.0.191:4533
Well it seems it is
OK, so how do I fix this?
Tolriq
4
I don’t know your network settings, your provider settings or anything. So I can’t really help.
As soon as that URL will open on your phone
http://10.0.0.191:4533
Then Symfonium will work.
OK, well do you have any idea where I should start? I’m very out of my depth here and I don’t know what to do
Tolriq
6
I’m sorry but I can’t do network and server side support this is way out of the scope.
