When I press play the ‘play’ icon has a spinning circle and alternates between play and pause. After 10-20 seconds it says “Too many errors” and stops. This is the case on my phone (Pixel) and in connecting to a Bluetooth receiver
Please open your OneDrive media provider settings, sign in again and save, then try playback.
I found your “Paul B Pixel” log. Microsoft rejects the saved authentication token, and automatic renewal fails too. The log doesn’t capture the final “Too many errors” sequence, so I can’t confirm that this explains the whole problem yet.
If it still happens after signing in, please send debug logs. Enable debug mode before sign in again and starting playback, reproduce the problem through the error message, then disable debug mode and upload promptly. Reply here with the upload description and the time it happened.
