Symfonium not honoring stop pressed on external players (DLNA)
So really can’t read ?
And no I can’t reproduce with my Sonos and my Yamaha …
This means I have at least one Sonos and one Yamaha UPnP device :wink: And I can’t reproduce on them because I already have workaround for them ?
Also when I talk about my needs for the physical remote button support, I’m pretty sure anyone who actually reads, understand that I do use a lot UPnP devices, and that I have a need and that the app fulfill that need right?
You do realize how you look right? All that time lost, just trying to prove me wrong and that you have the ultimate knowledge without actually reading anything written ?
Listen: things work perfectly fine as one would expect as a user when using Jellyfin, but they don’t when using Symfonium.
No matter what your gripes with UPNP may be: there obviusly is a way to make things work as they should. If you chose to make thinks work in some very, very weird way instead (forcing Symfonium in clearly unwanted situations), then all I can say is: rethink your decision, it was not a good one.
That said: I’ll send you another logfile right away. Can’t wait to continue this little exchange.
I give up you are clearly so entitled with yourself that you can’t even start to read and apologize …
Your need is not the only need, telling all the people who have different needs that they are stupid and weird is clearly inappropriate. And yet you keep doing it.
You can keep your log and do what you know you should do with it :wink:
As explained your need is not the only need, I could have added an option for the app to behave as you want, but seing your insults and behavior it will have to wait for someone else to request it.
You can call that “entitled” all you want, but excuse me that I’ll continue to call force resuming stopped playback when a user tries to switch input on an external device unwanted behavior.
That’s so blatantly obvious not what is supposed to happen that franky I can’t even begin to understand why are so defensive about it. It’s just wrong in every thinkable way… Come on man, you know it is. Otherwise you’d do the same with Chromecast etc. too, which you don’t.
New logfile is up, starting with selecting the Beosound speaker in Symfonium.
OMG STOP BEING SO STUPID PLEASE …
Again UPnP does not indicate that action unlike Chromecast, changing output or pressing next on a physical remote will produce the same result for most device.
So not it’s not unwanted because THIS IS WHAT I WANT …
So as said unless you apologize, I certainly won’t add an option to please someone who insult me and made me lost so much time just because he refuse to read .
Jesus Christ: EVEN AFTER STOPPING PLAYBACK IN SYMFONIUM IT FORCES ITSELF BACK ON.
That has nothing to do with being entitled or problems in UPNP. Why on Earth does Symfonium start playback again that already has been stopped in Symfonium itself?
AGAIN BECAUSE PAUSED IS NOT STOPPED :wink:
So now welcome to a couple of days ban, you clearly need to calm down, and maybe this will make you read this thread after all :wink:
After careful consideration I’d like to sincerely thank you for letting your wisdom shine upon me. I immediately opened a bug report on the Jellyfin Github so they can switch from their working sub-par solution to your non-working, yet clearly superior implementation. /sarcasm off
And now go ahead and ban me for good, which probably is what you think users deserve who insist on pointing out obvious flaws (pardon me, ‘deliberate decisions’ of course).
I guess you really can’t read, nor provide the asked logs, and yet feels the need to come and continue your actions.
So yes bye bye. Maybe someone with a little respect will report the same issue with proper logs and the option to work like you’d wanted will be added.
Sad you feels so entitled to assault without reading and could not understand the situation and other’s people needs …
