Symfonium not able to sort embedded rated tracks with a 0.5 - 5 scale?
I have a OneDrive music folder with 2000+ tracks, all manually rated via mp3tag; some example ratings being 4.5, 5.0, 1.0, 2.5, etc. However when I sort the tracks in the app by the “Rating” field, only the integer is acknowledged. For example, 5 star tracks are grouped correctly at the top but 4.5 and 4 star are grouped in a random mess together. If the app is misreading these tags, this also makes me wonder if my smart mixes are affected as well. On another note, when I use the in-app User Rating feature, it accommodates the 0.5-5 scale perfectly. Is this all intentional?
Upload description: Screenshot on app not sorting tracks properly due to embedded 0.5-5.0 star scale
One Drive
You probably mix rating and user rating.
But mandatory logs means mandatory:)
