Symfonium is randomly opening up
Randomly symfonium is just opening up on the notifications panel. It shows the song as paused so it doesn’t play the song. It happens often but I dont know what’s causing it to happen.
The only way I can get it to stop is if I force close the app. The issue with that is when I jump in the car I have to manually open it to get it to play music again. Its like random things at random parts of the day are just causing it to open but not play the song.
Its definitely something with the app because Spotify or Pandora dont do it if thats the last music app I was using.
I did my best to capture the log of the issue.
Adam’s s24 log
Phone either in use or just sitting there,
Symfonium shows in notification bar. Just pops up like it connected to android auto or BT device but doesn’t hit play.
Adam’s s24 log
Your logs show Symfonium restarting after Android stopped it, then restoring the previous track in a paused state. This is consistent with the Samsung media-session restoration behavior, and explains the controls appearing without music playing. I’ve discussed similar behavior here: Media session notification being bumped to front even when not in use.
Please enable Disable media session restoration in Symfonium’s settings. This prevents restoring those paused controls on startup, but disables quick resume, so it may affect resuming music from your car.
Your logs are from 15.0.1. Please also update to 15.1.0 and try again. Read the release notes and APK instructions; if Google Play has not approved that release yet, its announcement explains how to get the official APK.
If the controls still reappear after updating and enabling the setting, please send fresh debug logs. Enable debug mode before reproducing the full sequence, then disable it and upload promptly. Reply with the app version, upload description and the time the controls appeared so I can match the event.
OK, thank you. Done that, will keep an eye on it.
