Symfonium doesn't keep Repeat enabled (again)
Last week I updated Symfonium. After that, sometimes when it’s playing an album and reach the end of the last song, it stops playing even though Repeat is enabled and should instead restart the album again.
This bug occurred some months ago on another version and has been fixed since then, but it’s now present again. I already uploaded a log from the app.
EDIT: I forgot to say that the option Retain Player State is enabled
  1. Go to Artists page, select an artist, enter an album and play a song: the whole album should go into the playlist starting from the song selected.
  2. Enable Repeat (not Repeat Once) or have it already enabled.
  3. Let the phone playing for some time, maybe stop the music and come back later or use it normally for a while.
  4. Let it play again (I usually play it from the widget in my home screen) and let it reach the end of the last song.
  5. The music stops playing instead of restarting from the first song. If you enter Symfonium you notice Repeat is set to Off.
AriesBreath
Test with version 15.1.0 beta 1. See changelog for download links.
It seems the beta keeps the Repeat state. I’ll test it more and report in case of problems, thanks
