Symfonium 15.1.0 Beta 4 not showing in Android Auto
Beta
Hi everyone,
I updated Symfonium to version 15.1.0 Beta 4 (APK downloaded from the F-Droid repository), but this version is no longer showing up in Android Auto (Beta 17.6.663454-release). It doesn’t appear in the Android Auto settings either, so there’s no way to select it as the audio player.
Is there any way to fix this?
Device info:
  • Samsung Galaxy Note 9
  • Android 10
  • One UI 2.5
Best regards,
Fabrício from Brazil
OneDrive
Not working with Android Auto.
No additional Information.
No log.
Well I guess there’s not much I can say here …
Sorry. I’ll leave this question aside. I’ll wait for the next update of your app or Android auto in the hope that the problem will be solved.
Hugs and success.
