Swipe Guesture Sensitivity
Good day,
I’d like to request a setting for the swiping sensitivity.
Aka a slider that determines the distance you need to drag your finger for the swiping triggers to activate.
(In places like the compact player or adding songs to the queue.)
I find it really difficult to get used to the (imo) high swiping threshold. When i try to add songs to the queue or skip a song i often have to swipe multiple times until i swipe far enough.
It would improve (my) UX with easier swiping controls.
Before, i used the spotify app and there, the threshold was lower.
Thank you and good day!
There’s animations and vibrations so you know when it triggers, the interface supports many different things and actions and the values are set to avoid unwanted actions triggering too easily. I will not add an option sorry.
