Surround sound issues
I’m having issues with playback of surround audio with these formats:
  • Opus 5.1
    Shows correct codec and bitrate info, but there is no sound and an uneven progressing progress bar.
  • ac3 5.1 in mka container
    Transcodes to Opus 192 kb/s (also visible in Jellyfin dashboard), also no sound and an uneven progressing progress bar.
  • EAC3 Atmos in mka container
All of these files worked perfectly fine in older versions of Symfonium on the same device and still play perfectly fine in other apps (tested wholfin, which is terrible as an audio player, but the files work)
Logs uploaded with the names:
  • janik opus
  • janik ac3
  • janik eac3 atmos
My roommate already reported similar issues with the same formats and referenced the problems on my device:
Android TV
  1. Jellyfin as media provider
  2. Symfonium on TV-Box, sound output via Pioneer VSX-529
  3. play the files in the formats listed above
  4. no sound output :frowning:
TV-Box:
Xiaomi TV Box S (3rd Gen), model number MiTV-AFMU0
Android TV OS version:
14
Symfonium App version:
Version 15.1.0 TV (227812)
Jellyfin version:
12.0
Please let me know if there is any further information that could be useful for identifying the issue; I’ll gladly provide anything I can.
janik opus
All three logs reach the same playback path: 5.1 Opus decoded to multichannel PCM. The audio output also reports repeated timing mismatches, which points me toward the shared output path. I can’t yet tell what’s causing the silence.
How is the Xiaomi box connected to the Pioneer, directly by HDMI or through the TV? Please also include the Android TV audio-output setting.
Please capture an Android bug report while one of these tracks is playing silently and upload it to https://upload.symfonium.app. Add a description of the problem with the upload so I can identify it and check the system’s audio routing.
Thank you for the reply and please excuse the long wait.
My Pioneer is directly connected to the Xiaomi box using HDMI.
I have since updated to Version 16.0.0B1 TV (which is the newest beta build I could find).
eac3 atmos in mka container and ac3 5.1 in mka container are now working, so that is great news!
The issue with opus 5.1 persist, nothing changed on that front, except it now only arises on actual opus 5.1 tracks, because mka no longer transcodes to opus.
Setting the fixed PCM output to on (which is the temporary workaround you suggested in this comment: Surround audio playback issues after updating to app version 15.1 - #23 by Tolriq ) fixes the opus issue, but at the same time breaks playback for mka eac3 atmos, m4a eac3 atmos and mka ac3 5.1.
I have captured two android bug reports of the same opus 5.1 track:
First bug report:
  • Name: Android Debug Log Opus Fixed PCM 16b 48khz
  • Prefer hardware-accelerated codecs: Enabled
  • Fixed PCM output format: 16-bit / 48 kHz
  • Played opus 5.1 audio
    → audio is working as expected
Second bug report:
  • Fixed PCM output: Disabled
    → audio playback is silent and the progress bar still progresses unevenly
Opus stereo works fine with both Fixed PCM output enabled and disabled, the issues only arise on opus tracks with surroundsound.
Please let me know, if you need any other symfonium debug logs or further information.
The two reports narrow this down to the Xiaomi’s multichannel float PCM output path. With fixed PCM disabled, Android selects a float output route with inconsistent frame counts. The 16-bit report shows a different route that preserves all six channels, matching your working Opus test.
The MKA improvement matches the container fix in Beta 1. The Dolby failure with fixed PCM enabled still needs a separate capture, since these reports cover the Opus comparison.
Could you send Symfonium debug logs for one of the failing Dolby tracks with fixed PCM set to 16-bit / 48 kHz?
Enable debug mode, start the Dolby track from the beginning, then disable debug mode and upload promptly. Reply with the upload description and the time the failure occurred. I don’t need another Opus bug report.
Thank you!
I shared the requested symfonium debug log with the upload description “janik fixed pcm dolby”.
fixed pcm set to 16-bit / 48 kHz, played m4a eac3 atmos.
I don’t know exactly what you mean by “reply with the time the failure occurred”, I’m sorry. The only thing I can say is: the failure occured as soon as I pressed play, which was a few minutes ago, so probably around 11 p.m. CET, I hope that is the info you were asking for. Let me know, if you need anything else! :slight_smile:
